My drawing keeps closing when idle and I'd like to stop that but in the configuration variables the command is locked. I found an old wiki post where there is a .cfg file in C:\ProgramData\Bentley\...\Workspace that has that command with a %lock, but I can't seem to find that with the newer version. Thanks for any help.
In the Bentley workspace the standards.cfg, by default, is located in this directory in version 10.10.
C:\ProgramData\Bentley\OpenRoads Designer CE 10.10\Configuration\Organization
If you need to find where this variable is set in your workspace, you can try a debug. The following wiki's should be helpful.
communities.bentley.com/.../how-to-create-a-workspace-debug-filecommunities.bentley.com/.../how-to-read-a-msdebug-txt-debug-file
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
