Is there a way to change the linear stroking on a complex element? I have a linear template dropped along a complex element that consists of a line and an arc, and also has an active profile.
Essentially the complex element it's an edge of pavement for a driveway entrance, and I have an end condition dropped along said entrance, however I can not determine how to increase the template drop frequency.
Andy help would be greatly appreciated.
Thank you,
I'm using ORD 2021 R1 10.10.1.3
use the configuration variable to set a new stroking value
You can change this setting in the properties of the element. But, if it is created from a corridor I am not sure if this change will hold when the corridor is reprocessed. To ensure it will stay use the config varibales.
Marc
