I read in the what's new list that there is a new conditional picklist function for Item Types. In ORD I just can't find how to make it. Is there a tutorial on this?
www.youtube.com/watch
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Hi Marcus,
Thats is how you use conditional picklists. I want to know how to make them…
I'm running into the same problem. Is there already more information about this? Thanks!
Check out the May/June Coffee Corner presentation on Item Types. In the part 1 (May) presentation, about 20 min into it, there is discussion related to this topic. I would suggest watching these recordings to see if they offer enough guidance. If not, can you post what you want the item type to do and we can try to come up with something?
Coffee Corners:
Coffee Corner Presentations
You'll have to register for the event and you will get access to the recording.
Justin Guiliano, PE
Hi Justin,
I believe what he wants, is the same thing that Christiaan describes in this post:Item Types - Picklist or Expressions
I happen to face the same issue. It only seems to work into 1 'layer'. I can't get it to work in any way with multiple layers or dependancies.
