How to make one terrain model that covers 2 or more unconnected areas
When I import a DTM file that has several unconnected ditches in the same terrain model extra triangles are created to connect the areas. This gives incorrect volumes in quantity calculations.
The same happens when I try to create the terrain model from mesh elements. The best solution I can find is to use "Create terrain model from design meshes" this retains the element's boundaries but instead produces a terrain model for every single ditch area. This can end in 20 - 30 extra files.
Is it possible to make 1 terrain model that will cover all these ditch areas??
Openroads 2021 R1
  • Might not be applicable to your specific case but if you wanted to join two disconnected terrain models you could create a dummy close element joining the two and defined as a void. It might get complicated depending how complex the edge conditions of your terrain models are.
    If creating a complex terrain as suggested by others is too processor heavy, you could look at working with several LandXML exports of separate terrains and only update on demand? Lastly, you could also combine multiple LandXML's into a single LandXML and import as a single terrain model and it should honour the gaps between terrains.
  • yes, making several LandXML's is the best solution I found in openroads, making voids probably works but I have a lot of (over 100) unconnected ditches so its not feasable.
    I'm interested how you would combine multiple Land XMLs into one?   Is that a function in Openroads or copy pasting in Notepad?
  • No function in OpenRoads to combine LandXML's. They're ASCII files so you could combine in notepad by copying the 'Surface' node (and sub-nodes for Points and Faces) into another LandXML under the 'Surfaces' node. That's an iterative process. You could do it through VBA (in Excel) using a reference to MSXML - how quickly it would run would depend on the size of your terrains. If you have a couple of LandXML's available, I could put something together to test proof of concept?
  • OK great, thanks, I have a few here. Hope it works to just drag and drop files in the chat box
    <?xml version="1.0" encoding="UTF-8"?>
    <LandXML xsi:schemaLocation="http://www.landxml.org/schema/LandXML-1.2 http://www.landxml.org/schema/LandXML-1.2/LandXML-1.2.xsd" xmlns="http://www.landxml.org/schema/LandXML-1.2" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.2" date="2022-10-17" time="11:57:12">
      <Units>
        <Metric areaUnit="squareMeter" linearUnit="meter" volumeUnit="cubicMeter" temperatureUnit="celsius" pressureUnit="HPA"/>
      </Units>
      <Project name="EastFuen" desc="Ditches"/>
      <Application name="OpenRoads Designer" version="10.07.00.56" manufacturer="Bentley Systems, Inc." manufacturerURL="http://www.bentley.com"/>
      <Surfaces>
        <Surface name="Terrain Model (Element)">
          <SourceData>
            <Breaklines>
              <Breakline brkType="standard" name="Element1">
                <PntList3D>6137369.7820000006 271577.87 17.164999999999999 6137370.0619999999 271575.69699999999 17.170999999999999 6137370.0619999999 271575.69500000001 17.170999999999999 6137371.301 271565.79800000001 17.196999999999999 6137372.5060000001 271555.897 17.223000000000003 6137373.0970000001 271550.94500000001 17.236000000000001 6137373.1770000001 271550.26000000001 17.238</PntList3D>
                <Feature code="Breakline">
                  <Property label="id" value="0"/>
                  <Property label="UsrID" value="20000000"/>
                </Feature>
              </Breakline>
              <Breakline brkType="standard" name="Element2">
                <PntList3D>6137369.2240000013 271577.799 16.789999999999999 6137369.5080000004 271575.62700000004 16.798999999999999 6137369.5080000004 271575.625 16.798999999999999 6137370.767 271565.73200000002 16.838000000000001 6137371.9920000006 271555.83500000002 16.878 6137372.5920000002 271550.88500000001 16.896999999999998 6137372.6740000006 271550.20000000001 16.900000000000002</PntList3D>
                  <Property label="id" value="1"/>
                </Feature>
              </Breakline>
              <Breakline brkType="standard" name="Element3">
                <PntList3D>6137368.8770000003 271577.755 16.789999999999999 6137369.1610000003 271575.58299999998 16.798999999999999 6137369.1610000003 271575.58100000001 16.798999999999999 6137370.4190000007 271565.68900000001 16.838000000000001 6137371.6439999994 271555.79399999999 16.878 6137371.6439999994 271555.79300000001 16.878 6137372.2450000001 271550.84400000004 16.896999999999998 6137372.3269999996 271550.15899999999 16.900000000000002</PntList3D>
                  <Property label="id" value="2"/>
                </Feature>
              </Breakline>
              <Breakline brkType="standard" name="Element4">
                <PntList3D>6137366.1380000003 271577.40500000009 18.631 6137366.3219999997 271575.223 18.707000000000001 6137366.3210000014 271575.22100000002 18.707000000000001 6137367.0350000001 271565.272 19.111000000000001 6137368.1920000007 271555.37900000002 19.196000000000005 6137368.9819999998 271550.45799999998 19.088000000000001 6137369.1780000003 271549.78700000001 19.013999999999999</PntList3D>
                  <Property label="id" value="3"/>
                </Feature>
              </Breakline>
              <Breakline brkType="standard" name="Element5">
                <PntList3D>6137364.4920000006 271617.23100000009 17.062000000000001 6137364.5089999996 271617.109 17.062000000000001 6137364.773 271615.239 17.067 6137365.409 271610.68800000002 17.079000000000001 6137365.7379999999 271608.32000000001 17.085000000000001 6137366.0089999996 271606.348 17.09 6137366.0100000007 271606.34600000002 17.09 6137366.1449999996 271605.35999999999 17.093 6137367.4840000002 271595.47600000008 17.119 6137368.0100000007 271591.52100000001 17.129000000000001 6137368.1880000001 271590.17999999999 17.132999999999999 6137368.79 271585.587 17.145 6137369.2359999996 271582.12099999998 17.154</PntList3D>
                  <Property label="id" value="4"/>
                </Feature>
              </Breakline>
              <Breakline brkType="standard" name="Element6">
                <PntList3D>6137363.9539999999 271617.15600000002 16.699999999999999 6137363.9720000001 271617.033 16.699999999999999 6137364.2350000003 271615.163 16.704999999999998 6137364.8680000007 271610.61300000001 16.715 6137365.1960000023 271608.245 16.720000000000002 6137365.4660000009 271606.27399999998 16.725000000000001 6137365.4670000002 271606.272 16.725000000000001 6137365.6010000007 271605.28600000002 16.727 6137366.9349999996 271595.40299999999 16.75 6137366.9349999996 271595.402 16.75 6137367.4590000007 271591.44799999997 16.759 6137367.6360000009 271590.10700000002 16.762 6137368.2350000003 271585.51500000001 16.771999999999998 6137368.6789999995 271582.049 16.780000000000001</PntList3D>
                  <Property label="id" value="5"/>
                </Feature>
              </Breakline>
              <Breakline brkType="standard" name="Element7">
                <PntList3D>6137363.608 271617.10700000002 16.699999999999999 6137363.625 271616.984 16.699999999999999 6137363.8880000012 271615.11499999999 16.704999999999998 6137364.5210000006 271610.565 16.715 6137364.8490000013 271608.19699999999 16.720000000000002 6137365.1200000001 271606.22600000008 16.725000000000001 6137365.1210000003 271606.22399999999 16.725000000000001 6137365.2540000007 271605.23800000001 16.727 6137366.5880000014 271595.35600000009 16.75 6137367.1120000007 271591.402 16.759 6137367.2889999999 271590.06200000003 16.762 6137367.8880000003 271585.46999999997 16.771999999999998 6137368.3320000013 271582.00400000002 16.780000000000001</PntList3D>
                  <Property label="id" value="6"/>
                </Feature>
              </Breakline>
              <Breakline brkType="standard" name="Element8">
                <PntList3D>6137361.3790000007 271616.79300000001 18.199999999999999 6137361.3979999991 271616.67000000004 18.199999999999999 6137361.7000000002 271614.80800000002 18.177 6137362.2759999996 271610.25300000008 18.226000000000003 6137362.6230000006 271607.89000000001 18.219000000000001 6137362.8629999999 271605.91600000008 18.243000000000002 6137362.8640000001 271605.91399999999 18.244 6137362.9930000007 271604.92800000001 18.248000000000001 6137364.2850000001 271595.049 18.297999999999998 6137364.7719999999 271591.09299999999 18.332000000000001 6137364.9040000001 271589.74699999997 18.364999999999998 6137365.4119999995 271585.147 18.437000000000001 6137365.7320000008 271581.66899999999 18.528000000000002</PntList3D>
                  <Property label="id" value="7"/>
                </Feature>
              </Breakline>
            </Breaklines>
          </SourceData>
          <Definition surfType="TIN">
            <Pnts>
              <P id="1">6137369.1780000003 271549.78700000001 19.013999999999999</P>
              <P id="2">6137372.3269999996 271550.15899999999 16.900000000000002</P>
              <P id="3">6137372.6740000006 271550.20000000001 16.900000000000002</P>
              <P id="4">6137373.1770000001 271550.26000000001 17.238</P>
              <P id="5">6137368.9819999998 271550.45799999998 19.088000000000001</P>
              <P id="6">6137372.2450000001 271550.84400000004 16.896999999999998</P>
              <P id="7">6137372.5920000002 271550.88500000001 16.896999999999998</P>
              <P id="8">6137373.0970000001 271550.94500000001 17.236000000000001</P>
              <P id="9">6137368.1920000007 271555.37900000002 19.196000000000005</P>
              <P id="10">6137371.6439999994 271555.79300000001 16.878</P>
              <P id="11">6137371.6439999994 271555.79399999999 16.878</P>
              <P id="12">6137371.9920000006 271555.83500000002 16.878</P>
              <P id="13">6137372.5060000001 271555.897 17.223000000000003</P>
              <P id="14">6137367.0350000001 271565.272 19.111000000000001</P>
              <P id="15">6137370.4190000007 271565.68900000001 16.838000000000001</P>
              <P id="16">6137370.767 271565.73200000002 16.838000000000001</P>
              <P id="17">6137371.301 271565.79800000001 17.196999999999999</P>
              <P id="18">6137366.3210000014 271575.22100000002 18.707000000000001</P>
              <P id="19">6137366.3219999997 271575.223 18.707000000000001</P>
              <P id="20">6137369.1610000003 271575.58100000001 16.798999999999999</P>
              <P id="21">6137369.1610000003 271575.58299999998 16.798999999999999</P>
              <P id="22">6137369.5080000004 271575.625 16.798999999999999</P>
              <P id="23">6137369.5080000004 271575.62700000004 16.798999999999999</P>
              <P id="24">6137370.0619999999 271575.69500000001 17.170999999999999</P>
              <P id="25">6137370.0619999999 271575.69699999999 17.170999999999999</P>
              <P id="26">6137366.1380000003 271577.40500000009 18.631</P>
              <P id="27">6137368.8770000003 271577.755 16.789999999999999</P>
              <P id="28">6137369.2240000013 271577.799 16.789999999999999</P>
              <P id="29">6137369.7820000006 271577.87 17.164999999999999</P>
              <P id="30">6137365.7320000008 271581.66899999999 18.528000000000002</P>
              <P id="31">6137368.3320000013 271582.00400000002 16.780000000000001</P>
              <P id="32">6137368.6789999995 271582.049 16.780000000000001</P>
              <P id="33">6137369.2359999996 271582.12099999998 17.154</P>
              <P id="34">6137365.4119999995 271585.147 18.437000000000001</P>
              <P id="35">6137367.8880000003 271585.46999999997 16.771999999999998</P>
              <P id="36">6137368.2350000003 271585.51500000001 16.771999999999998</P>
              <P id="37">6137368.79 271585.587 17.145</P>
              <P id="38">6137364.9040000001 271589.74699999997 18.364999999999998</P>
              <P id="39">6137367.2889999999 271590.06200000003 16.762</P>
              <P id="40">6137367.6360000009 271590.10700000002 16.762</P>
              <P id="41">6137368.1880000001 271590.17999999999 17.132999999999999</P>
              <P id="42">6137364.7719999999 271591.09299999999 18.332000000000001</P>
              <P id="43">6137367.1120000007 271591.402 16.759</P>
              <P id="44">6137367.4590000007 271591.44799999997 16.759</P>
              <P id="45">6137368.0100000007 271591.52100000001 17.129000000000001</P>
              <P id="46">6137364.2850000001 271595.049 18.297999999999998</P>
              <P id="47">6137366.5880000014 271595.35600000009 16.75</P>
              <P id="48">6137366.9349999996 271595.402 16.75</P>
              <P id="49">6137366.9349999996 271595.40299999999 16.75</P>
              <P id="50">6137367.4840000002 271595.47600000008 17.119</P>
              <P id="51">6137362.9930000007 271604.92800000001 18.248000000000001</P>
              <P id="52">6137365.2540000007 271605.23800000001 16.727</P>
              <P id="53">6137365.6010000007 271605.28600000002 16.727</P>
              <P id="54">6137366.1449999996 271605.35999999999 17.093</P>
              <P id="55">6137362.8640000001 271605.91399999999 18.244</P>
              <P id="56">6137362.8629999999 271605.91600000008 18.243000000000002</P>
              <P id="57">6137365.1210000003 271606.22399999999 16.725000000000001</P>
              <P id="58">6137365.1200000001 271606.22600000008 16.725000000000001</P>
              <P id="59">6137365.4670000002 271606.272 16.725000000000001</P>
              <P id="60">6137365.4660000009 271606.27399999998 16.725000000000001</P>
              <P id="61">6137366.0100000007 271606.34600000002 17.09</P>
              <P id="62">6137366.0089999996 271606.348 17.09</P>
              <P id="63">6137362.6230000006 271607.89000000001 18.219000000000001</P>
              <P id="64">6137364.8490000013 271608.19699999999 16.720000000000002</P>
              <P id="65">6137365.1960000023 271608.245 16.720000000000002</P>
              <P id="66">6137365.7379999999 271608.32000000001 17.085000000000001</P>
              <P id="67">6137362.2759999996 271610.25300000008 18.226000000000003</P>
              <P id="68">6137364.5210000006 271610.565 16.715</P>
              <P id="69">6137364.8680000007 271610.61300000001 16.715</P>
              <P id="70">6137365.409 271610.68800000002 17.079000000000001</P>
              <P id="71">6137361.7000000002 271614.80800000002 18.177</P>
              <P id="72">6137363.8880000012 271615.11499999999 16.704999999999998</P>
              <P id="73">6137364.2350000003 271615.163 16.704999999999998</P>
              <P id="74">6137364.773 271615.239 17.067</P>
              <P id="75">6137361.3979999991 271616.67000000004 18.199999999999999</P>
              <P id="76">6137361.3790000007 271616.79300000001 18.199999999999999</P>
              <P id="77">6137363.625 271616.984 16.699999999999999</P>
              <P id="78">6137363.9720000001 271617.033 16.699999999999999</P>
              <P id="79">6137363.608 271617.10700000002 16.699999999999999</P>
              <P id="80">6137364.5089999996 271617.109 17.062000000000001</P>
              <P id="81">6137363.9539999999 271617.15600000002 16.699999999999999</P>
              <P id="82">6137364.4920000006 271617.23100000009 17.062000000000001</P>
            </Pnts>
            <Faces>
              <F>1 6 5</F>
              <F>1 2 6</F>
              <F>2 3 7</F>
              <F>2 7 6</F>
              <F>3 4 7</F>
              <F>4 8 7</F>
              <F>5 10 9</F>
              <F>5 6 10</F>
              <F>6 7 12</F>
              <F>6 12 10</F>
              <F>7 8 13</F>
              <F>7 13 12</F>
              <F>9 11 14</F>
              <F>9 10 11</F>
              <F>10 12 11</F>
              <F>11 12 16</F>
              <F>11 16 15</F>
              <F>11 15 14</F>
              <F>12 13 17</F>
              <F>12 17 16</F>
              <F>14 18 30</F>
              <F>14 30 51</F>
              <F>14 51 56</F>
              <F>14 56 67</F>
              <F>14 67 76</F>
              <F>14 15 18</F>
              <F>15 16 22</F>
              <F>15 22 20</F>
              <F>15 20 18</F>
              <F>16 17 24</F>
              <F>16 24 22</F>
              <F>17 25 24</F>
              <F>18 20 19</F>
              <F>18 19 26</F>
              <F>18 26 30</F>
              <F>19 21 26</F>
              <F>19 20 21</F>
              <F>20 22 21</F>
              <F>21 27 26</F>
              <F>21 22 23</F>
              <F>21 23 28</F>
              <F>21 28 27</F>
              <F>22 24 23</F>
              <F>23 25 29</F>
              <F>23 29 28</F>
              <F>23 24 25</F>
              <F>25 33 29</F>
              <F>26 27 30</F>
              <F>27 28 32</F>
              <F>27 32 31</F>
              <F>27 31 30</F>
              <F>28 29 33</F>
              <F>28 33 32</F>
              <F>30 31 34</F>
              <F>30 34 38</F>
              <F>30 38 46</F>
              <F>30 46 51</F>
              <F>31 32 35</F>
              <F>31 35 34</F>
              <F>32 33 36</F>
              <F>32 36 35</F>
              <F>33 37 36</F>
              <F>34 35 38</F>
              <F>35 36 40</F>
              <F>35 40 39</F>
              <F>35 39 38</F>
              <F>36 37 40</F>
              <F>37 41 40</F>
              <F>38 39 42</F>
              <F>38 42 46</F>
              <F>39 40 44</F>
              <F>39 44 43</F>
              <F>39 43 42</F>
              <F>40 41 44</F>
              <F>41 45 44</F>
              <F>42 43 46</F>
              <F>43 44 47</F>
              <F>43 47 46</F>
              <F>44 45 48</F>
              <F>44 48 47</F>
              <F>45 50 48</F>
              <F>46 47 51</F>
              <F>47 49 52</F>
              <F>47 52 51</F>
              <F>47 48 49</F>
              <F>48 50 49</F>
              <F>49 50 54</F>
              <F>49 54 53</F>
              <F>49 53 52</F>
              <F>51 52 55</F>
              <F>51 55 56</F>
              <F>52 53 57</F>
              <F>52 57 55</F>
              <F>53 54 61</F>
              <F>53 61 59</F>
              <F>53 59 57</F>
              <F>55 58 56</F>
              <F>55 57 58</F>
              <F>56 58 63</F>
              <F>56 63 67</F>
              <F>57 60 58</F>
              <F>57 59 60</F>
              <F>58 60 64</F>
              <F>58 64 63</F>
              <F>59 61 62</F>
              <F>59 62 60</F>
              <F>60 62 65</F>
              <F>60 65 64</F>
              <F>61 66 62</F>
              <F>62 66 65</F>
              <F>63 68 67</F>
              <F>63 64 68</F>
              <F>64 65 69</F>
              <F>64 69 68</F>
              <F>65 66 70</F>
              <F>65 70 69</F>
              <F>67 68 71</F>
              <F>67 71 75</F>
              <F>67 75 76</F>
              <F>68 72 71</F>
              <F>68 69 73</F>
              <F>68 73 72</F>
              <F>69 70 73</F>
              <F>70 74 73</F>
              <F>71 72 77</F>
              <F>71 77 75</F>
              <F>72 73 78</F>
              <F>72 78 77</F>
              <F>73 74 78</F>
              <F>74 82 80</F>
              <F>74 80 78</F>
              <F>75 77 79</F>
              <F>75 79 76</F>
              <F>76 79 81</F>
              <F>77 81 79</F>
              <F>77 78 81</F>
              <F>78 80 82</F>
              <F>78 82 81</F>
            </Faces>
          </Definition>
        </Surface>
      </Surfaces>
    </LandXML>
    <LandXML xsi:schemaLocation="http://www.landxml.org/schema/LandXML-1.2 http://www.landxml.org/schema/LandXML-1.2/LandXML-1.2.xsd" xmlns="http://www.landxml.org/schema/LandXML-1.2" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.2" date="2022-10-17" time="11:57:32">
      <Units>
      </Units>
      <Surfaces>
        <Surface name="Terrain Model (Element)1">
          <SourceData>
            <Breaklines>
                <PntList3D>6137364.4920000006 271617.23100000009 17.062000000000001 6137364.5089999996 271617.109 17.062000000000001 6137364.773 271615.239 17.067 6137365.409 271610.68800000002 17.079000000000001 6137365.7379999999 271608.32000000001 17.085000000000001 6137366.0089999996 271606.348 17.09 6137366.0100000007 271606.34600000002 17.09 6137366.1449999996 271605.35999999999 17.093 6137367.4840000002 271595.47600000008 17.119 6137368.0099999998 271591.52100000001 17.129000000000001 6137368.1880000001 271590.17999999999 17.132999999999999 6137368.79 271585.587 17.145 6137369.2359999996 271582.12099999998 17.154</PntList3D>
                </Feature>
              </Breakline>
                <PntList3D>6137363.9539999999 271617.15600000002 16.699999999999999 6137363.9720000001 271617.033 16.699999999999999 6137364.2350000003 271615.163 16.704999999999998 6137364.8680000007 271610.61300000001 16.715 6137365.1960000014 271608.245 16.720000000000002 6137365.466 271606.27399999998 16.725000000000001 6137365.4670000002 271606.272 16.725000000000001 6137365.6010000007 271605.28600000002 16.727 6137366.9350000005 271595.40299999999 16.75 6137366.9350000005 271595.402 16.75 6137367.4590000007 271591.44799999997 16.759 6137367.6359999999 271590.10700000002 16.762 6137368.2350000013 271585.51500000001 16.771999999999998 6137368.6789999995 271582.049 16.780000000000001</PntList3D>
                </Feature>
              </Breakline>
                <PntList3D>6137363.608 271617.10700000002 16.699999999999999 6137363.625 271616.984 16.699999999999999 6137363.8879999993 271615.11499999999 16.704999999999998 6137364.5210000006 271610.565 16.715 6137364.8490000013 271608.19699999999 16.720000000000002 6137365.1200000001 271606.22600000008 16.725000000000001 6137365.1210000003 271606.22399999999 16.725000000000001 6137365.2540000007 271605.23800000001 16.727 6137366.5880000014 271595.35600000009 16.75 6137367.1120000016 271591.402 16.759 6137367.2889999999 271590.06200000003 16.762 6137367.8880000003 271585.46999999997 16.771999999999998 6137368.3320000013 271582.00400000002 16.780000000000001</PntList3D>
                </Feature>
              </Breakline>
                <PntList3D>6137361.3790000007 271616.79300000001 18.199999999999999 6137361.398 271616.67000000004 18.199999999999999 6137361.6999999993 271614.80800000002 18.177 6137362.2760000005 271610.25300000008 18.226000000000003 6137362.6230000006 271607.89000000001 18.219000000000001 6137362.8629999999 271605.91600000008 18.243000000000002 6137362.8640000001 271605.91399999999 18.244 6137362.9930000007 271604.92800000001 18.248000000000001 6137364.2850000001 271595.049 18.297999999999998 6137364.7719999999 271591.09299999999 18.332000000000001 6137364.904000001 271589.74699999997 18.364999999999998 6137365.4119999995 271585.147 18.437000000000001 6137365.7319999998 271581.66899999999 18.528000000000002</PntList3D>
                </Feature>
              </Breakline>
            </Breaklines>
          </SourceData>
            <Pnts>
              <P id="1">6137365.7319999998 271581.66899999999 18.528000000000002</P>
              <P id="2">6137368.3320000013 271582.00400000002 16.780000000000001</P>
              <P id="3">6137368.6789999995 271582.049 16.780000000000001</P>
              <P id="4">6137369.2359999996 271582.12099999998 17.154</P>
              <P id="5">6137365.4119999995 271585.147 18.437000000000001</P>
              <P id="6">6137367.8880000003 271585.46999999997 16.771999999999998</P>
              <P id="7">6137368.2350000013 271585.51500000001 16.771999999999998</P>
              <P id="8">6137368.79 271585.587 17.145</P>
              <P id="9">6137364.904000001 271589.74699999997 18.364999999999998</P>
              <P id="10">6137367.2889999999 271590.06200000003 16.762</P>
              <P id="11">6137367.6359999999 271590.10700000002 16.762</P>
              <P id="12">6137368.1880000001 271590.17999999999 17.132999999999999</P>
              <P id="13">6137364.7719999999 271591.09299999999 18.332000000000001</P>
              <P id="14">6137367.1120000016 271591.402 16.759</P>
              <P id="15">6137367.4590000007 271591.44799999997 16.759</P>
              <P id="16">6137368.0099999998 271591.52100000001 17.129000000000001</P>
              <P id="17">6137364.2850000001 271595.049 18.297999999999998</P>
              <P id="18">6137366.5880000014 271595.35600000009 16.75</P>
              <P id="19">6137366.9350000005 271595.402 16.75</P>
              <P id="20">6137366.9350000005 271595.40299999999 16.75</P>
              <P id="21">6137367.4840000002 271595.47600000008 17.119</P>
              <P id="22">6137362.9930000007 271604.92800000001 18.248000000000001</P>
              <P id="23">6137365.2540000007 271605.23800000001 16.727</P>
              <P id="24">6137365.6010000007 271605.28600000002 16.727</P>
              <P id="25">6137366.1449999996 271605.35999999999 17.093</P>
              <P id="26">6137362.8640000001 271605.91399999999 18.244</P>
              <P id="27">6137362.8629999999 271605.91600000008 18.243000000000002</P>
              <P id="28">6137365.1210000003 271606.22399999999 16.725000000000001</P>
              <P id="29">6137365.1200000001 271606.22600000008 16.725000000000001</P>
              <P id="30">6137365.4670000002 271606.272 16.725000000000001</P>
              <P id="31">6137365.466 271606.27399999998 16.725000000000001</P>
              <P id="32">6137366.0100000007 271606.34600000002 17.09</P>
              <P id="33">6137366.0089999996 271606.348 17.09</P>
              <P id="34">6137362.6230000006 271607.89000000001 18.219000000000001</P>
              <P id="35">6137364.8490000013 271608.19699999999 16.720000000000002</P>
              <P id="36">6137365.1960000014 271608.245 16.720000000000002</P>
              <P id="37">6137365.7379999999 271608.32000000001 17.085000000000001</P>
              <P id="38">6137362.2760000005 271610.25300000008 18.226000000000003</P>
              <P id="39">6137364.5210000006 271610.565 16.715</P>
              <P id="40">6137364.8680000007 271610.61300000001 16.715</P>
              <P id="41">6137365.409 271610.68800000002 17.079000000000001</P>
              <P id="42">6137361.6999999993 271614.80800000002 18.177</P>
              <P id="43">6137363.8879999993 271615.11499999999 16.704999999999998</P>
              <P id="44">6137364.2350000003 271615.163 16.704999999999998</P>
              <P id="45">6137364.773 271615.239 17.067</P>
              <P id="46">6137361.398 271616.67000000004 18.199999999999999</P>
              <P id="47">6137361.3790000007 271616.79300000001 18.199999999999999</P>
              <P id="48">6137363.625 271616.984 16.699999999999999</P>
              <P id="49">6137363.9720000001 271617.033 16.699999999999999</P>
              <P id="50">6137363.608 271617.10700000002 16.699999999999999</P>
              <P id="51">6137364.5089999996 271617.109 17.062000000000001</P>
              <P id="52">6137363.9539999999 271617.15600000002 16.699999999999999</P>
              <P id="53">6137364.4920000006 271617.23100000009 17.062000000000001</P>
            </Pnts>
            <Faces>
              <F>1 2 5</F>
              <F>1 5 9</F>
              <F>1 9 17</F>
              <F>1 17 22</F>
              <F>1 22 38</F>
              <F>1 38 47</F>
              <F>2 3 6</F>
              <F>2 6 5</F>
              <F>3 4 7</F>
              <F>3 7 6</F>
              <F>4 8 7</F>
              <F>5 6 9</F>
              <F>6 7 11</F>
              <F>6 11 10</F>
              <F>6 10 9</F>
              <F>7 8 11</F>
              <F>8 12 11</F>
              <F>9 13 17</F>
              <F>9 10 13</F>
              <F>10 15 14</F>
              <F>10 14 13</F>
              <F>10 11 15</F>
              <F>11 12 15</F>
              <F>12 16 15</F>
              <F>13 14 17</F>
              <F>14 15 18</F>
              <F>14 18 17</F>
              <F>15 16 19</F>
              <F>15 19 18</F>
              <F>16 21 19</F>
              <F>17 18 22</F>
              <F>18 19 20</F>
              <F>18 20 23</F>
              <F>18 23 22</F>
              <F>19 21 20</F>
              <F>20 21 25</F>
              <F>20 25 24</F>
              <F>20 24 23</F>
              <F>22 23 26</F>
              <F>22 26 27</F>
              <F>22 27 38</F>
              <F>23 24 28</F>
              <F>23 28 26</F>
              <F>24 25 32</F>
              <F>24 32 30</F>
              <F>24 30 28</F>
              <F>26 28 29</F>
              <F>26 29 27</F>
              <F>27 29 34</F>
              <F>27 34 38</F>
              <F>28 31 29</F>
              <F>28 30 31</F>
              <F>29 31 35</F>
              <F>29 35 34</F>
              <F>30 32 33</F>
              <F>30 33 31</F>
              <F>31 33 36</F>
              <F>31 36 35</F>
              <F>32 37 33</F>
              <F>33 37 36</F>
              <F>34 39 38</F>
              <F>34 35 39</F>
              <F>35 36 40</F>
              <F>35 40 39</F>
              <F>36 37 41</F>
              <F>36 41 40</F>
              <F>38 39 42</F>
              <F>38 42 46</F>
              <F>38 46 47</F>
              <F>39 40 44</F>
              <F>39 44 43</F>
              <F>39 43 42</F>
              <F>40 41 44</F>
              <F>41 45 44</F>
              <F>42 43 48</F>
              <F>42 48 46</F>
              <F>43 44 49</F>
              <F>43 49 48</F>
              <F>44 45 49</F>
              <F>45 51 49</F>
              <F>45 53 51</F>
              <F>46 50 47</F>
              <F>46 48 50</F>
              <F>47 50 52</F>
              <F>48 49 52</F>
              <F>48 52 50</F>
              <F>49 51 53</F>
              <F>49 53 52</F>
            </Faces>
          </Definition>
        </Surface>
      </Surfaces>
    </LandXML>
    <LandXML xsi:schemaLocation="http://www.landxml.org/schema/LandXML-1.2 http://www.landxml.org/schema/LandXML-1.2/LandXML-1.2.xsd" xmlns="http://www.landxml.org/schema/LandXML-1.2" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.2" date="2022-10-17" time="11:57:45">
      <Units>
      </Units>
      <Surfaces>
        <Surface name="Terrain Model (Element)2">
          <SourceData>
            <Breaklines>
                <PntList3D>6137358.1030000011 271663.571 17.217000000000002 6137358.1180000007 271663.47500000003 17.217000000000002 6137359.4460000014 271654.79800000001 17.256 6137360.9369999999 271644.92700000008 17.295999999999999 6137361.5270000007 271640.98000000004 17.312000000000001 6137361.0610000007 271640.908 16.998000000000001 6137361.1270000003 271640.41500000004 16.995000000000001 6137361.2000000002 271639.92099999997 16.997 6137361.273 271639.42800000001 16.999000000000002 6137361.2880000006 271639.32900000009 16.999000000000002 6137361.3170000007 271639.13099999999 17 6137361.3250000002 271639.08199999999 17 6137361.3280000016 271639.06200000003 17 6137361.3310000002 271639.04300000001 17 6137361.3310000002 271639.038 17 6137361.3320000013 271639.03600000002 17 6137361.3320000013 271639.033 17 6137361.3469999991 271638.93400000001 17.001000000000001 6137361.6390000014 271636.96000000002 17.007000000000001 6137361.9300000006 271634.98599999998 17.013000000000005 6137363.3669999996 271625.11300000001 17.041 6137363.6500000004 271623.15000000002 17.045999999999999 6137363.7359999996 271622.54399999999 17.047999999999998 6137363.8839999996 271621.51300000004 17.050999999999998</PntList3D>
                </Feature>
              </Breakline>
                <PntList3D>6137357.1890000002 271663.42999999999 16.600000000000001 6137357.203999999 271663.33399999997 16.600000000000001 6137358.5010000002 271654.65500000009 16.619 6137358.5010000002 271654.65400000004 16.619 6137359.9640000006 271644.78100000002 16.640000000000001 6137360.5420000004 271640.83399999997 16.648 6137360.5429999996 271640.83100000001 16.648 6137360.6140000001 271640.33900000004 16.650000000000002 6137360.6860000007 271639.84499999997 16.651 6137360.7580000004 271639.35200000001 16.652000000000001 6137360.773 271639.25300000008 16.652000000000001 6137360.801 271639.05499999999 16.652000000000001 6137360.8090000004 271639.00599999999 16.652000000000001 6137360.8119999999 271638.98599999998 16.652000000000001 6137360.8150000013 271638.967 16.652000000000001 6137360.8150000013 271638.962 16.652000000000001 6137360.8160000006 271638.96000000002 16.652000000000001 6137360.8160000006 271638.95699999999 16.652000000000001 6137360.8300000001 271638.85800000001 16.653000000000002 6137361.1189999999 271636.88299999997 16.657 6137361.4080000008 271634.90899999999 16.661000000000001 6137362.8340000007 271625.03600000002 16.682000000000002 6137363.1160000013 271623.07400000002 16.686 6137363.2010000004 271622.46799999999 16.688000000000002 6137363.3480000002 271621.43700000003 16.690000000000001</PntList3D>
                </Feature>
              </Breakline>
                <PntList3D>6137356.8430000003 271663.37700000004 16.600000000000001 6137356.858 271663.28100000002 16.600000000000001 6137358.1550000003 271654.60200000001 16.619 6137359.6180000007 271644.73000000004 16.640000000000001 6137360.1960000014 271640.78200000001 16.648 6137360.1970000006 271640.78000000009 16.648 6137360.2680000002 271640.288 16.650000000000002 6137360.3399999999 271639.79300000001 16.651 6137360.4110000003 271639.29999999999 16.652000000000001 6137360.4270000001 271639.201 16.652000000000001 6137360.4550000001 271639.00300000008 16.652000000000001 6137360.4630000014 271638.95400000009 16.652000000000001 6137360.466 271638.93400000001 16.652000000000001 6137360.4689999996 271638.91500000004 16.652000000000001 6137360.4689999996 271638.90999999997 16.652000000000001 6137360.4700000007 271638.908 16.652000000000001 6137360.4700000007 271638.90500000009 16.652000000000001 6137360.4840000002 271638.80600000004 16.653000000000002 6137360.773 271636.83199999999 16.657 6137361.0619999999 271634.85800000001 16.661000000000001 6137362.4879999999 271624.98700000002 16.682000000000002 6137362.7699999996 271623.02399999998 16.686 6137362.8550000023 271622.41800000001 16.688000000000002 6137363.0020000003 271621.38699999999 16.690000000000001</PntList3D>
                </Feature>
              </Breakline>
                <PntList3D>6137354.6150000002 271663.03499999997 18.103000000000005 6137354.6380000012 271662.94 18.098000000000003 6137355.841 271654.25099999999 18.178999999999998 6137355.841 271654.25 18.178999999999998 6137357.2879999997 271644.38099999999 18.210000000000001 6137358.2010000004 271640.48599999998 17.993000000000002 6137358.2019999996 271640.48300000001 17.993000000000002 6137358.2480000006 271639.98800000001 18.010999999999999 6137358.3170000007 271639.49400000001 18.013999999999999 6137358.5150000006 271639.02000000002 17.928999999999998 6137358.5450000009 271638.92300000001 17.920000000000005 6137358.5320000006 271638.71900000004 17.948 6137358.5219999999 271638.66700000002 17.960000000000001 6137358.5180000002 271638.64600000001 17.965 6137358.5150000006 271638.62599999999 17.970000000000002 6137358.5130000003 271638.62099999998 17.971 6137358.5130000003 271638.61900000001 17.971 6137358.5120000001 271638.61600000004 17.972000000000001 6137358.5070000002 271638.51400000008 17.984999999999999 6137358.7379999999 271636.53200000001 18.028000000000002 6137359.0950000007 271634.57000000001 17.986999999999998 6137359.0950000007 271634.56900000002 17.986999999999998 6137360.3360000001 271624.67700000008 18.132000000000001 6137360.6060000006 271622.71500000008 18.143999999999998 6137360.6809999999 271622.10800000001 18.152000000000001 6137360.8229999999 271621.07699999999 18.157</PntList3D>
                </Feature>
              </Breakline>
            </Breaklines>
          </SourceData>
            <Pnts>
              <P id="1">6137360.8229999999 271621.07699999999 18.157</P>
              <P id="2">6137363.0020000003 271621.38699999999 16.690000000000001</P>
              <P id="3">6137363.3480000002 271621.43700000003 16.690000000000001</P>
              <P id="4">6137363.8839999996 271621.51300000004 17.050999999999998</P>
              <P id="5">6137360.6809999999 271622.10800000001 18.152000000000001</P>
              <P id="6">6137362.8550000023 271622.41800000001 16.688000000000002</P>
              <P id="7">6137363.2010000004 271622.46799999999 16.688000000000002</P>
              <P id="8">6137363.7359999996 271622.54399999999 17.047999999999998</P>
              <P id="9">6137360.6060000006 271622.71500000008 18.143999999999998</P>
              <P id="10">6137362.7699999996 271623.02399999998 16.686</P>
              <P id="11">6137363.1160000013 271623.07400000002 16.686</P>
              <P id="12">6137363.6500000004 271623.15000000002 17.045999999999999</P>
              <P id="13">6137360.3360000001 271624.67700000008 18.132000000000001</P>
              <P id="14">6137362.4879999999 271624.98700000002 16.682000000000002</P>
              <P id="15">6137362.8340000007 271625.03600000002 16.682000000000002</P>
              <P id="16">6137363.3669999996 271625.11300000001 17.041</P>
              <P id="17">6137359.0950000007 271634.56900000002 17.986999999999998</P>
              <P id="18">6137359.0950000007 271634.57000000001 17.986999999999998</P>
              <P id="19">6137361.0619999999 271634.85800000001 16.661000000000001</P>
              <P id="20">6137361.4080000008 271634.90899999999 16.661000000000001</P>
              <P id="21">6137361.9300000006 271634.98599999998 17.013000000000005</P>
              <P id="22">6137358.7379999999 271636.53200000001 18.028000000000002</P>
              <P id="23">6137360.773 271636.83199999999 16.657</P>
              <P id="24">6137361.1189999999 271636.88299999997 16.657</P>
              <P id="25">6137361.6390000014 271636.96000000002 17.007000000000001</P>
              <P id="26">6137358.5070000002 271638.51400000008 17.984999999999999</P>
              <P id="27">6137358.5120000001 271638.61600000004 17.972000000000001</P>
              <P id="28">6137358.5130000003 271638.61900000001 17.971</P>
              <P id="29">6137358.5130000003 271638.62099999998 17.971</P>
              <P id="30">6137358.5150000006 271638.62599999999 17.970000000000002</P>
              <P id="31">6137358.5180000002 271638.64600000001 17.965</P>
              <P id="32">6137358.5219999999 271638.66700000002 17.960000000000001</P>
              <P id="33">6137358.5320000006 271638.71900000004 17.948</P>
              <P id="34">6137360.4840000002 271638.80600000004 16.653000000000002</P>
              <P id="35">6137360.8300000001 271638.85800000001 16.653000000000002</P>
              <P id="36">6137360.4700000007 271638.90500000009 16.652000000000001</P>
              <P id="37">6137360.4700000007 271638.908 16.652000000000001</P>
              <P id="38">6137360.4689999996 271638.90999999997 16.652000000000001</P>
              <P id="39">6137360.4689999996 271638.91500000004 16.652000000000001</P>
              <P id="40">6137358.5450000009 271638.92300000001 17.920000000000005</P>
              <P id="41">6137360.466 271638.93400000001 16.652000000000001</P>
              <P id="42">6137361.3469999991 271638.93400000001 17.001000000000001</P>
              <P id="43">6137360.4630000014 271638.95400000009 16.652000000000001</P>
              <P id="44">6137360.8160000006 271638.95699999999 16.652000000000001</P>
              <P id="45">6137360.8160000006 271638.96000000002 16.652000000000001</P>
              <P id="46">6137360.8150000013 271638.962 16.652000000000001</P>
              <P id="47">6137360.8150000013 271638.967 16.652000000000001</P>
              <P id="48">6137360.8119999999 271638.98599999998 16.652000000000001</P>
              <P id="49">6137360.4550000001 271639.00300000008 16.652000000000001</P>
              <P id="50">6137360.8090000004 271639.00599999999 16.652000000000001</P>
              <P id="51">6137358.5150000006 271639.02000000002 17.928999999999998</P>
              <P id="52">6137361.3320000013 271639.033 17</P>
              <P id="53">6137361.3320000013 271639.03600000002 17</P>
              <P id="54">6137361.3310000002 271639.038 17</P>
              <P id="55">6137361.3310000002 271639.04300000001 17</P>
              <P id="56">6137360.801 271639.05499999999 16.652000000000001</P>
              <P id="57">6137361.3280000016 271639.06200000003 17</P>
              <P id="58">6137361.3250000002 271639.08199999999 17</P>
              <P id="59">6137361.3170000007 271639.13099999999 17</P>
              <P id="60">6137360.4270000001 271639.201 16.652000000000001</P>
              <P id="61">6137360.773 271639.25300000008 16.652000000000001</P>
              <P id="62">6137360.4110000003 271639.29999999999 16.652000000000001</P>
              <P id="63">6137361.2880000006 271639.32900000009 16.999000000000002</P>
              <P id="64">6137360.7580000004 271639.35200000001 16.652000000000001</P>
              <P id="65">6137361.273 271639.42800000001 16.999000000000002</P>
              <P id="66">6137358.3170000007 271639.49400000001 18.013999999999999</P>
              <P id="67">6137360.3399999999 271639.79300000001 16.651</P>
              <P id="68">6137360.6860000007 271639.84499999997 16.651</P>
              <P id="69">6137361.2000000002 271639.92099999997 16.997</P>
              <P id="70">6137358.2480000006 271639.98800000001 18.010999999999999</P>
              <P id="71">6137360.2680000002 271640.288 16.650000000000002</P>
              <P id="72">6137360.6140000001 271640.33900000004 16.650000000000002</P>
              <P id="73">6137361.1270000003 271640.41500000004 16.995000000000001</P>
              <P id="74">6137358.2019999996 271640.48300000001 17.993000000000002</P>
              <P id="75">6137358.2010000004 271640.48599999998 17.993000000000002</P>
              <P id="76">6137360.1970000006 271640.78000000009 16.648</P>
              <P id="77">6137360.1960000014 271640.78200000001 16.648</P>
              <P id="78">6137360.5429999996 271640.83100000001 16.648</P>
              <P id="79">6137360.5420000004 271640.83399999997 16.648</P>
              <P id="80">6137361.0610000007 271640.908 16.998000000000001</P>
              <P id="81">6137361.5270000007 271640.98000000004 17.312000000000001</P>
              <P id="82">6137357.2879999997 271644.38099999999 18.210000000000001</P>
              <P id="83">6137359.6180000007 271644.73000000004 16.640000000000001</P>
              <P id="84">6137359.9640000006 271644.78100000002 16.640000000000001</P>
              <P id="85">6137360.9369999999 271644.92700000008 17.295999999999999</P>
              <P id="86">6137355.841 271654.25 18.178999999999998</P>
              <P id="87">6137355.841 271654.25099999999 18.178999999999998</P>
              <P id="88">6137358.1550000003 271654.60200000001 16.619</P>
              <P id="89">6137358.5010000002 271654.65400000004 16.619</P>
              <P id="90">6137358.5010000002 271654.65500000009 16.619</P>
              <P id="91">6137359.4460000014 271654.79800000001 17.256</P>
              <P id="92">6137354.6380000012 271662.94 18.098000000000003</P>
              <P id="93">6137354.6150000002 271663.03499999997 18.103000000000005</P>
              <P id="94">6137356.858 271663.28100000002 16.600000000000001</P>
              <P id="95">6137357.203999999 271663.33399999997 16.600000000000001</P>
              <P id="96">6137356.8430000003 271663.37700000004 16.600000000000001</P>
              <P id="97">6137357.1890000002 271663.42999999999 16.600000000000001</P>
              <P id="98">6137358.1180000007 271663.47500000003 17.217000000000002</P>
              <P id="99">6137358.1030000011 271663.571 17.217000000000002</P>
            </Pnts>
            <Faces>
              <F>1 2 5</F>
              <F>1 5 82</F>
              <F>2 6 5</F>
              <F>2 4 3</F>
              <F>2 3 6</F>
              <F>3 4 8</F>
              <F>3 8 7</F>
              <F>3 7 6</F>
              <F>4 81 8</F>
              <F>5 9 13</F>
              <F>5 13 82</F>
              <F>5 6 9</F>
              <F>6 10 9</F>
              <F>6 7 10</F>
              <F>7 8 11</F>
              <F>7 11 10</F>
              <F>8 12 11</F>
              <F>8 81 12</F>
              <F>9 10 13</F>
              <F>10 15 14</F>
              <F>10 14 13</F>
              <F>10 11 15</F>
              <F>11 12 16</F>
              <F>11 16 15</F>
              <F>12 81 16</F>
              <F>13 14 17</F>
              <F>13 17 22</F>
              <F>13 22 82</F>
              <F>14 15 19</F>
              <F>14 19 17</F>
              <F>15 16 20</F>
              <F>15 20 19</F>
              <F>16 81 21</F>
              <F>16 21 20</F>
              <F>17 19 18</F>
              <F>17 18 22</F>
              <F>18 19 23</F>
              <F>18 23 22</F>
              <F>19 20 23</F>
              <F>20 21 24</F>
              <F>20 24 23</F>
              <F>21 25 24</F>
              <F>21 81 25</F>
              <F>22 23 26</F>
              <F>22 26 66</F>
              <F>22 66 82</F>
              <F>23 24 34</F>
              <F>23 34 26</F>
              <F>24 25 35</F>
              <F>24 35 34</F>
              <F>25 81 42</F>
              <F>25 42 35</F>
              <F>26 34 32</F>
              <F>26 32 30</F>
              <F>26 30 28</F>
              <F>26 28 27</F>
              <F>26 27 66</F>
              <F>27 28 29</F>
              <F>27 29 51</F>
              <F>27 51 66</F>
              <F>28 30 29</F>
              <F>29 30 31</F>
              <F>29 31 51</F>
              <F>30 32 31</F>
              <F>31 32 51</F>
              <F>32 34 33</F>
              <F>32 33 51</F>
              <F>33 38 40</F>
              <F>33 40 51</F>
              <F>33 34 38</F>
              <F>34 35 36</F>
              <F>34 36 38</F>
              <F>35 42 44</F>
              <F>35 44 36</F>
              <F>36 44 37</F>
              <F>36 37 38</F>
              <F>37 46 39</F>
              <F>37 39 38</F>
              <F>37 44 46</F>
              <F>38 39 41</F>
              <F>38 41 43</F>
              <F>38 43 40</F>
              <F>39 46 41</F>
              <F>40 43 49</F>
              <F>40 49 60</F>
              <F>40 60 62</F>
              <F>40 62 51</F>
              <F>41 46 48</F>
              <F>41 48 43</F>
              <F>42 81 53</F>
              <F>42 53 52</F>
              <F>42 52 44</F>
              <F>43 48 50</F>
              <F>43 50 56</F>
              <F>43 56 49</F>
              <F>44 52 45</F>
              <F>44 45 46</F>
              <F>45 52 54</F>
              <F>45 54 47</F>
              <F>45 47 46</F>
              <F>46 47 48</F>
              <F>47 54 48</F>
              <F>48 54 57</F>
              <F>48 57 58</F>
              <F>48 58 50</F>
              <F>49 56 60</F>
              <F>50 59 56</F>
              <F>50 58 59</F>
              <F>51 67 66</F>
              <F>51 62 67</F>
              <F>52 53 54</F>
              <F>53 81 55</F>
              <F>53 55 54</F>
              <F>54 55 57</F>
              <F>55 58 57</F>
              <F>55 81 58</F>
              <F>56 59 61</F>
              <F>56 61 60</F>
              <F>58 81 59</F>
              <F>59 81 63</F>
              <F>59 63 61</F>
              <F>60 61 64</F>
              <F>60 64 62</F>
              <F>61 63 65</F>
              <F>61 65 64</F>
              <F>62 64 67</F>
              <F>63 81 65</F>
              <F>64 68 67</F>
              <F>64 65 68</F>
              <F>65 81 69</F>
              <F>65 69 68</F>
              <F>66 67 70</F>
              <F>66 70 82</F>
              <F>67 68 71</F>
              <F>67 71 70</F>
              <F>68 69 72</F>
              <F>68 72 71</F>
              <F>69 81 73</F>
              <F>69 73 72</F>
              <F>70 71 74</F>
              <F>70 74 75</F>
              <F>70 75 82</F>
              <F>71 76 77</F>
              <F>71 77 74</F>
              <F>71 72 76</F>
              <F>72 73 78</F>
              <F>72 78 76</F>
              <F>73 81 80</F>
              <F>73 80 78</F>
              <F>74 77 75</F>
              <F>75 83 82</F>
              <F>75 77 83</F>
              <F>76 79 77</F>
              <F>76 78 79</F>
              <F>77 79 83</F>
              <F>78 80 79</F>
              <F>79 80 84</F>
              <F>79 84 83</F>
              <F>80 81 85</F>
              <F>80 85 84</F>
              <F>82 83 86</F>
              <F>83 84 88</F>
              <F>83 88 86</F>
              <F>84 85 89</F>
              <F>84 89 88</F>
              <F>85 91 89</F>
              <F>86 88 87</F>
              <F>86 87 92</F>
              <F>86 92 93</F>
              <F>87 88 92</F>
              <F>88 89 90</F>
              <F>88 90 94</F>
              <F>88 94 92</F>
              <F>89 91 90</F>
              <F>90 91 95</F>
              <F>90 95 94</F>
              <F>91 98 95</F>
              <F>92 94 96</F>
              <F>92 96 93</F>
              <F>93 96 99</F>
              <F>94 97 96</F>
              <F>94 95 97</F>
              <F>95 98 99</F>
              <F>95 99 97</F>
              <F>96 97 99</F>
            </Faces>
          </Definition>
        </Surface>
      </Surfaces>
    </LandXML>
  • Hi Pete, thanks for the samples. The .XLSM attached works fine on the samples you shared, so should be able to scale up to suit. My initial suggestion of copying in the Surface node for each terrain into a single LandXML results in only one LandXML to import but multiple terrain models (which isn't what you want). In the .XLSM attached, populate the source path and click the orange button - that should combine multiple surfaces into one. The SourceData node is stripped out in the combined LandXML file, therefore ORD builds the terrain from the Definition only so it maintains the gaps across the terrain between input surfaces
    LandXML utilities.xlsm
    Answer Verified By: Pete Otiv
Reply
