I have a 22k point survey that I am in the middle of processing. It's not huge. I have to do a bit of point modification, but each observation/point change takes a minimum of a minute after hitting apply. Is this normal? Is there possibly a setting I have wrong? A file in the wrong location? Something that will drag everything down. I have to modify a decent amount of shots and its just bottle necking.
Microstatio0n V8i (Select series 3) Version 08.11.09.459
Bentley InRoads Survey V8i (Select series 2) V08.11.07.615
Intel(R) Xeon(R) W-2125 CPU @ 4.00GHz 4.01 GHz
32.0 GB
Really? No suggestions on how to speed things up? Move everything to my C drive? Something??? If this is just how InRoads runs, that's unacceptable.
Joe, in my experience the speed has been mostly memory-based. But it depends on whether it's observational raw data or fixed point data. But you can go to Tools > Survey Options > General tab and toggle off the "Automatic Refresh", and then do a manual refresh as needed or desired. You may also want to toggle off 'Use Custom Ops" on that same tab. Beyond that, which you may already have done, is to toggle off the Line Styles in the View Attributes. ... but those should be off anyway when you're post-processing a field book.
