The premade tables are missing some information I need, and I was wondering how to edit these tables WITHIN Openroads. I know the XML file is editable and you can change things around there but the way my system is set up I cannot access/edit those files. For example, in the attached able I would like to add sections for easting and northing coords.
To be able to edit geometry reports within the program would be a lot easier than working with the xsl, but it's not possible currently. Do you have a project workset standards folder where you can make a copy of the xsl and edit? Maybe have that path added to the configuration variable CIVIL_REPORTS_SUBDIRECTORIES, or your local folder like C:\Program Files\Bentley\OpenRoads Designer CE 10.10\OpenRoadsDesigner\Default\Reports\CivilGeometry
