I am suddenly having difficulty with drainage profiles in drawing models. The Utility Properties are available when selecting drainage elements in the profile model window in the design model, but when moving to the drawing model created from the Named Boundary tool, and selecting the same drainage element, no Utility Properties are available, only the regular Properties. It feels like I'm missing something basic here, but I can't think of what it might be. I've seen this happen before, but switching to the design model and then back to the drawing model always "reset" the Utility Properties. But that is not working now. Any suggestions appreciated. Thanks.
You are not missing anything, although like you I swear this used to work. But maybe not. I have a thread here somewhere about the same problem.
Here's what is happening: (NOTE in 2022 R1, one of the release announcements noted improvements in this area. I haven't yet had time to investigate)
Some utility properties are exposed in both the MicroStation property panel as well as the Utility property panel. Whatever is shown in the MS panel will also be available (for annotation or whatever) when the utility feature is in a reference file. If the property is shown only in the Utility property panel, it is not exposed for use when the utility feature is in a reference.
The solution is straightforward. Bentley could combine the two property panels (everything available in the MS properties) but they seem disinclined to do so. So, we have to do it ourselves by way of item types.
Example: you want to label the time of concentration of catchment in your drawing model. Since Tc is only listed in the Utility properties it is not available in the drawing model. So, you make an Item Type whose sole purpose is to duplicate the Tc property in the MS properties. Thus, you can see it in the drawing model and label it.
Not too horrible, but still annoys me some.
But, there is another wrinkle. One of the powerful tools for drainage and utilities is bulk editing in the flex tables. So, (in NC for example) the utilities group very specifically define pipe materials for water lines. Wham Bam - make a user data extension for the 10-20 pipe materials they use which makes a handy pick list as well as bulk editing capabilities. But, UDE are not included in the MS properties panel. So, you have to make an Item Type which serves only to duplicate the custom property you have already created as UDE.
So, to solve your problems, I think you'll need to consider the following:
One additional note: Even after doing all the above, I discovered (just this week) that the properties still do not flow into projected profile runs. All the work I had done to get necessary properties exposed in the drawings worked fine for profiles runs, but not the projected profile runs. I had to attach items again to the features in the projected profile.
Robert Garrett Senior Consultant
www.envisioncad.com
A few follow-up questions:
1. A colleague at NCDOT told me that Bentley told him that Item Works "don't work for drainage". Well, I experimented and found mixed success. I found that I could attach an item type to a stormwater conduit, and I could see in the Explorer that it was attached when I went to the list under the Items category in the Explorer. But, when I selected the conduit and looked at its Properties, the Item Type was not shown. I submitted an SR to Bentley and got this response:
Bug 819764: [D&U] Item Type assigned to a Feature Definition will not apply to the Pipe when it is placed.
How have you gotten around this issue?
2. Like you, my goal here is to annotate drainage profiles projected onto roadway plan and profile sheets. So, you attached Item Types to the drainage nodes and conduits AFTER they were projected?
3. I thought one way around this was to have ORD import the utility properties for the referenced drainage. I trigger this by selecting the referenced drainage element and from the flyout selecting Utility Properties. ORD then pops up a warning asking if I want to import the drainage database properties. If I click YES, then those properties become available. I thought that was the intent. Could this be an alternative to using Item Types?
Karl Dauber, PEAdvance ConsultingLaurens County, SCkarldauber@advconsult.netwww.advconsult.netwww.linkedin.com/in/karldauber
Thank you Robert. This is very helpful.
Hi Robert,Although I see the Item Type properties for drainage elements in the active file, when selecting drainage elements in a referenced file, the Item Type properties are missing. The Item Types are there, but the property values are blank. Any idea what could be causing this? I'm working in a design model, not a drawing model.
Also, when in a drawing model for a profile in that same file which contains the drainage (not a reference) the Item Types are not there at all. If I attempt to attached Item Types to the drainage in the profile drawing model, I get the message: "Element in reference that is not currently active."
