Is there a tool in ORD that I can create a generic curb for aerial extraction with a .5ft vertical offset from the GUT to the TOC and then a .5ft horizontal offset from the TOC to the BOC? I would like to collect the GUT and then automatically have the TOC and BOC offset drawn in. Intergraph had this option but I don't see anything in ORD. Attached is an example of what I am looking for.
Hello Stephen - I don't have a productive suggestion for the curb offsets, however I would not use the TMPL linking codes. In the past this workflow was unstable, and results would vary. ORD desperately needs a tool to accomplish this task. Keep us posted if you find a work around or have a valid workflow.
Cliff
unfortunately, I am unable to attach the video.
Hello Stephen - Apologize for the delay. I would like to see the workaround video. Let me know if I can help with the sharing issue.
