Drape surface command ORD equivalent?
I am creating a proposed terrain model, working in a 3D model file. I want to drape some linework on to another terrain model so that they pick up its elevations, as the drape surface command worked in InRoads. These new lines cross existing features so unable to bring the existing in. I did try using Quick profile from surface but was unable to select the terrain model [set to active]. I am using ORD 2021 R1 Update 10 10.10.01.03 Thank you for reading and greatful for help.
