How to import .asc file in open roads foe creating terrain
Hello Atif,
You can use Create Terrain Model from ASCII File under Additional method of Terrain Model.
Here is the workflow to Create terrain model from ASCII file: communities.bentley.com/.../video-create-terrain-model-from-ascii
Purva Lakde
thanks Purva but this is .asc format not ascii
Atif, which data do you have in your .asc file?
Can you give me your mail id .I am not able to share it here.I will share the file with you
Atif, I would suggest you to please try to use Scalable Terrain Model, here you will need to create 3D file > Store STM model > Then after use Raster DEM files(.asc) to Add Points. If still issue is persisting, please use the link below to upload your dataset.
https://bentley.sharefile.com/r-r94349caa075848c9b14ddaf6f6bee416
