I want to convert an alignment into 3D polyline. Is there any specific tool like in InRoads SS2 or any other way?
Hi Santosh,
You can export the 3d linear feature of your alignment in your 3d model to dwg or use fence to file for cad dgn.
This will naturally be the stroked linestring based on your alignments 3d stroking settings as you can't export real 2d geometric events to 3d (in any software).
Mark
