So I found that a lot of the 10.10 expressions don't work in 10.11. for example:
10.10:
LookUp.GetEntry("PayItems","Item", this.Pay_Item).Unit
10.11:
LookUp.GetEntry("PayItems","DESCRIPTION", this["Description"])["BIDITEM"]
same expression, different formatting. That being said, what is the new method of getting sloped and planar areas? In 10.10 it was:
System.Math.Round(this.GetElement().MeshSurfaceEntity_PlanarArea)
but that doesn't work in 10.11.
The Help is absolutely no help.
Thanks in advance,
Mike
Hi Mike,
Although the autofill provides the revised formatting, we're still using the "old" formatting and it works fine for us.
Mark
