style set editor box is opened when i click on it.i want to change my chainage interval.
tools>style set ediot (but its now working),how to fix it?
Hello Anurag,
I would suggest you to create a new plan display from File > New plan display> display your model.
If still issue is persisting then go for Reset Configuration :
Go to All programs > Bentley > MXRoad > MX options > Reset Configuration. You can also refer Restoredefaultssettings .
Please refer the following steps for your reference.
Purva Lakde
HI.
none of the above worked.
