We are using Microstation Version SS10 and InRoads Version SS2.
Cogo Points and alignments/figures are created daily on a huge project. Below is the process and problem.
Process for the day is as follows:
Open Microstation>open file2. Open InRoads Suite>Open ALG with xin3. Work. Creating/editing points, etc.4. Save ALG, close InRoads5. Save .dgn and save settings (sometimes compress file [have tried compressing before and after closing InRoads during trial and error in finding the root of the problem])6. Close .dgnNext day, when I open Microstation and then the subsequent file, it stays on a grey screen and will not open... corrupt.To fix, I create a new file and merge to master the previous one (have tried only copying in instead of merging to master). And then sometimes the points I created or edited are lost and must be reassigned thru the Horizontal Curve Set>Events function in InRoads to be relabeled and reassigned.At the end of the day I have even saved and closed out of everything, then immediately tried re-opening the file I was working in and it opened just fine. Almost as if overnight something is happening.
Has anyone else experienced this problem? If so, what was your solution?
Thanks!
Part of the issue may well be that I do not think InRoads SS2 is certified to run over MicroStation SS10, and I KNOW that it is not certified to run on Windows 10/11. While I can't be sure that's the problem, it could contribute to some of the weirdness you are seeing.
There is a Civil discussion board where you may be able to search more answers, and get more targeted help. You can move your post over there with the "Move" option or "More" underneath your post.
MaryB
I can't remember if we ever got this to work. We switched to using PowerInRoads SS2 and PowerInRoads SS10. PIR SS2 is bundled with the older microstation that works.
BTW, I thought Bentley's licensing was now that if you run MicroStation with InRoads on top you pay for an ORD Suite license + a MicroStation license, where running PowerInRoads is only the ORD suite license. We've been removing MicroStation completely because of this.
