I want to get construction limits in a format that I can export to a Microstation dgn file. Once you have a model, is there an easy way to do this?
Wilson,
Page 26-28 of this Ohio DOT training guide describes a workflow that might work for you. https://tas.transportation.ohio.gov/CADD/OHDOT/Standards/OHDOT%20Utilities/Training/OpenRoads/ORD%20Design/Guides/OHDOT_ORD_Design_600_Right-of-Way.pdf
Matt
Answer Verified By: Wilson Elgin
This seems to work, but I am using templates from the out of the box imperial standards (CE 10.10) and the tie points all have different names (like TL_End Cond Fill Tie" or Cut Tie, etc - and there is no option to select more than one. Seems like there has to be a simpler way. This does work though, using an offset of zero and picking one of these lines.
