View Control Missing
Question: Is there another way to access 'View Control' other than long right click in the view window? Or is there a direction you can point me in that may be the problem based on screenshots of my configuration file and the mvba files that are in that location it points to?
Issue: I am under the impression that 'View Control' is very important in making sure your 2D edits are translating to the 3D World. I have looked up other posts on this issue and the closest one to solving my problem is the post where there was a line missing in their workspace configuration file. But it was never mentioned what that line was. I have uninstalled and reinstalled OpenRoads to try to solve this issue and tried to insert a configuration line suggested by another post in Bentley Communities with no luck. I believe that the issue maybe in a configuration file. Any suggestions will be appreciated.
