Does Last Mile Utilities V2.1 Provided in below link work for ORD 2021 Release 1? https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/52965/last-mile-utilities---set-of-utilities-for-openroads-openrail-designerI downloaded the zip file and placed the contents as mentioned in help guide. But still unable to load it in MDL applications.
Hi Nusrath,
It works well with ORD 2021 R1, make sure you followed the process mentioned in the PDF document available in the Last Mile utilities folder.
Hi Rohith, Thanks. I had placed the Last Mile utilities at:
C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\Assemblies\LastMileUtilities_v2.1\LastMileUtilities and it works fine.However, the slope lines are represented as Tadpoles and when I export to drawing file, it appears as Line. Like the screenshot below:
How can i get the Tadpole annotation while exporting to Cadd?
In 2022 R1, new option for DWG export is available follow the below image:
Using this you will get the proper output without any additional settings. Else If you wish to continue with 2021 R1 you need to have proper settings while exporting to DWG.
I cant change the version to 2022 as I am currently working on project configured for 2021 in PW. Can you help me with the settings for exporting to DWG in 2021?
