Hi all,
I am trying to create corridor in PRT SS10. I have imported the alignment from .xml file. when i select the corridor modeller and the alignment modeller tool. It is showing not a valid tool for corridor baseline.
please help on this.
Hi Shudhir,
I am not an expert in Bentley Power Rail Track, but one think came into my mind. If you hover over the element (e.g. alignment), is it saying this is a 3D element? I think you may be working on 3D elements, and the solution for you could be creating a 2D. See article.
___
Also, please keep in mind that questions in English should be posted in the dedicated forum:
OpenRoads/OpenSite Forum (English).
This will help not only us, but also you to get a proper answer. I am moving your post to the English language forum. :)
Best regards,
Klaudia
