How do I add a drainage node graphically using the cursor?
If you are trying to create a drainage node within a Drainage and Utility database, then you use the Place Node or Place Nodes tools. You can place the inlet graphically or by using Civil Accudraw (to place by Station and Offset for example).
Karl Dauber, PEAdvance ConsultingLaurens County, SCkarldauber@advconsult.netwww.advconsult.netwww.linkedin.com/in/karldauber
