I am trying to import vertical geometry by importing a txt file, but I keep getting an error that says import failed? Not sure why?
Does the text format and selected column(s) in the Import Wizard correctly?
jing jing (o'.'o)
Answer Verified By: Chris Key
That was the issue, thanks
Hi Paul,
please keep in mind that questions in English should be posted in the dedicated forum:
OpenRoads/OpenSite Forum (English).
This will help not only us, but also you to get a proper answer. ;)
__
I am happy the issue has been solved.
Best regards,
Klaudia
