In ORD can a corridor be created using a baseline horizontal alignment BUT no design vertical? InRoads allowed the creation of a corridor with NONE as the design vertical.
Short answer is no. A corridor requires horizontal and vertical geometry for the basis of its development. If your template is constructed in a manner that does not need a profile, then to speed up processing I would suggest applying a constant elevation to the line via the vertical tools. This will be faster than using existing ground as the active profile.
Eddie Giese, PEProduction Manager | Senior Roadway EngineerLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
