Hey,
I recently got my hands on OpenRoads Designer 2022. My issue is as follows:
When I create a complex alignment and open a profile view with an active terrain model, the terrain model appears to be fragmented (see pic). This happens when the alignment exceeds around 1400m in length. When drawing a straight alignment it seems to work a bit better, but fragmentation starts occurring after a certain distance. The terrain model itself has dense triangles, so the fragmentation isn't a result of void zones in the model. This problem doesn't appear in the 2021 version.
The terrain model used has been updated to ORD2022.
Any help regarding this issue is much appreciated.
-Sam
I think there must be something else going on on your pc.The screenshot below is from the files you shared. All I did was open the files and display the profile. As you can see, the terrain is displayed along the entire length without any straight lines.
Jan
Hey Jan,
Both me and my coworker had the same issue by repeating the same steps. Both of us are running 10.11.00.115.
I'm working with Samuli and we have the same shared configuration. There was some testing done with stroking tolerance values and it was found out that those values painted yellow can't be 0 in configuration, though you can change those values to 0 afterwards in model for example when linear template is placed.
So everything is fine now considering this case after those values were reverted back to original 0.02. Thanks for everybody answering in this thread
Best Regards,
Lauri
