Hello everyone,
I am a new OpenRoads user switching from Power InRoads.
I am trying to export a set of cross sections created in ORD into a one (1) dwg file. The problem is when I select a sheet set which includes more than one section or use a fence to select number of sections, the export method doesn't work and created dwg file is empty.
The exporting process works when I select only one cross section.
Thank you in advance for your help.
Arash
It works perfectly if you export to a V8 dgn.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/155757/creating-cross-sections-in-openroads-designer
Maybe do that and then convert to a dwg?
I tried it by exporting to V8 dgn first and then exporting to dwg, but still it's not working.
If the steps in the linked post are followed you will get a set of static cross sections just like V8i/InRoads produces. Did you get that far? From there I would expect you should be able to get it into dwg format.
No I didn't. I have to figure out how to make a set of static sections.
ORDumpsterfire will not produce static sections.
Once you have the ORD sections, follow the steps in the linked post.
You will end up with static cross sections EXACTLY like V8i/InRoads (mainly because Benzi Papo is a genius).
