Hello everyone,
I am a new OpenRoads user switching from Power InRoads.
I am trying to export a set of cross sections created in ORD into a one (1) dwg file. The problem is when I select a sheet set which includes more than one section or use a fence to select number of sections, the export method doesn't work and created dwg file is empty.
The exporting process works when I select only one cross section.
Thank you in advance for your help.
Arash
I'm gonna try it. Thank you again.
Hi Arash,
Make sure your DWG export settings includes merging of References. No need for any manual fence to file processes.
Also, make sure the drawing models are selected at the same time as the Sheet models so they come out together. This is required for both DWG and DGN when trying to get a multi-model merged output.
Mark
Thank you Mark. I selected both drawing and sheet models and it worked. The only issue is that more than one dwg file is created and I need to delete all except one which includes all cross sections.
Have a look in your DWG export settings. The setting you use for "Non-Default Design models" and "Create Seperate Files for Sheets" controls this and should allow you to keep it all in one DWG file.
It works. Thank you.
