I'm working on a display for an open house. I've used the bing map raster feature many times now and have been quite happy with it.
This time, however, after I plot faint yellow gridlines show up. I've tested to confirm they're related to the aerial. Has anyone had experiences with this and is there a solution?
I ran into the same issue with yellow gridlines through my aerials. This previous forum might help: https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/227576/grid-lines-and-shading-issues-when-printing-double-stack-plan-sheets-with-aerials?ReplySortBy=CreatedDate&ReplySortOrder=Ascending
TLDR; you have a reference file on your plotted file which is either moved/scaled and/or a 3D file attached which forces the aerials to print with gridlines.
I isolated each reference by turning them off and on and printing them until I found the one which was forcing the gridlines to print.
