Does anyone know what is meant by: Contours must be "tagged" with the elevation?
How do you "tag" 2D contour elements with elevations?
Hi Benzi,
I believe it just means that there is text on top of the contour:
How to create 3d contours from 2d contours - OpenRail Forum - OpenRail - Bentley Communities
Mark
