OpenRoads Designer Drainage Model Conduit Inverts
Hello All,
I started my drainage model by placing the network without adjusting any of the conduit inverts. However, when I want to change an invert whether it is the upstream or downstream invert, it does not change and will change back to the original elevation it had. Both stop and end inverts are set to True, so I am not sure why they are not wanting to adjust. Any insight on how I can go about changing my invert elevations would be helpful. Thank you, very much appreciated.
Valerie Alanis
