ORD - Feature Definition / Element Template / Level display issues
When working in ORD, our Feature Definition for the survey existing boundary for the terrain comes in at a weight of 4. It should be a 1 per our company standards. I looked at the element template for this and it is using the level "RDY_Exisitng Ground" and is set to "By Level (4)" When I go to the Level Manager, the "By Level" Is set to 1. There is a disconnect here and I am having problems figuring out how to fix this. Has anyone else had this issue?
Parents Reply Children
