Open Roads Transition not working properly
I tried to use the transition tool on a pavement design where I have it going from 0.5% to 1.5%. I have the corridor with both templates and a gap between them. I added a transition between and made sure the points were connected correctly and then deleted the slope constraints on the edge of pavement. The slider bar looks correct, but the model shows this transition being a few inches above where it should be.
