I have raster image (Aerials) referenced where I set the transparency to 70%. Transparency is showing correctly in dgn but when I print to pdf the raster transparency is ignored. I know checking the rasterized option is a solution but the printed pdf is not text searchable. How can I have transparent raster image with text searchable pdf. Any help would be highly appreciated. I am using Open Roads Designer & FDOT Plot Config.
You need to print in "Rasterized" mode for raster transparency to print:
Connect- Raster transparency ignored on print - Printing and Plotting Forum - Printing and Plotting - Bentley Communities
Alternatively, you can attach your raster to a Level or reference file and control transparency that way.
This may help, but that variable is not available till ORD 10.11:
Printing transparent references- How to set 'Print Adjusted Colors' automatically on - MicroStation Wiki - MicroStation - Bentley Communities
Mark
After doing some trial and error, it seems like you can get raster images to print with a transparency without rasterizing your pdf if your aerial imagery is directly attached via raster manager into the sheet that is being printed, as opposed to being nested in references or referenced. Also i have found that if the aerial is still attached in any of the references it effects the aerial directly attached to the drawing and prevents both from printing with a transparency if the referenced file is in the fence of the printed area. In summary some weird stuff is going on and there is no great way to fix it without detaching all of your aerial from all of your referenced drawings, and then directly attaching said aerial using the reference manager to the sheet you wish to print.
Click on your reference in the Reference Dialog. Go to settings-->Adjust Colors. Make sure "Print Adjusted Colors" is checked. This worked for me. I didnt need to do this in SS4 or SS10. ORD is a different story though. . .
We house rasters in there own dgn file. When adjusting the display properties we make a copy of the raster dgn and adjust the settings in the raster manager. This way users only need to replace the raster dgn in the reference manager to have the transparent version . Also it ensures everyone is using the same settings.
Zane Pratt
Civil Designer
