Civil Labeler- DONT HIT UNDO!!!
Hello all,
I am an FDOT Connect User.  We are having issues when using the new civil labeler tool.  If we try to undo a command, it deletes all callouts that we have created using the civil labeler tool, and it doesn't allow you to re-do the command.  We have lost so much progress on plan labeling because of this.  Has anyone else had this problem, and if so what is the work around?
  • We have experienced this as well, though my understanding was that this problem occurs independent of the FDOT WorkSpace. We are currently running FDOT Connect10.10 MR2 (built on ORD 10.10.21.04).
    Eddie Giese, PE
    Production Manager | Senior Roadway Engineer
    Licensed in FL & PA
    ACEC FDOTConnect Instructor on behalf of FDOT
    Patel, Greene & Associates, LLC
    PowerGEOPAK V8i SS10 (08.11.09.918)
    OpenRoads Designer 2021 R2 (10.10.21.4)
    OpenRoads Designer 2020 R3 (10.9.0.91)
    ProjectWise Explorer CE 10.0.3.453
    LumenRT CE Update 14 (16.14.60.98)
    premier-scholar-badge road-designer-badge
  • Thanks for your response, Eddie!  I asked them about this at FLUG this year, and I was told it's a bentley issue.  Not sure how to correct or work around.  Have y'all found a solution?
  • Not so much a solution as a best practice. We try to keep our TEXTRD files federated as much as possible to minimize the impact of corruption or, in this case, re-work due to a bug. That, and avoiding the Undo tool in any TEXTRD files...
    Eddie Giese, PE
    Licensed in FL & PA
Reply
    Eddie Giese, PE
    Licensed in FL & PA
