Hello ,
I am training with OpenRoads Design but every training video refers to setting up to WorkSpaces and worksets to Imperial or metric standards/Training and Examples. I do not think my OpenRoads came with these configurations.
Please assist .
Hi Aubel,
OpenRoads does come with these workspaces and work set. On installation of ORD, you get the workspace and workset. You can find the same on the startup page of ORD
Answer Verified By: Aubel Bonga
Hello Amita, Thank you for replying . I have checked that already, unfortunately mine only came with a Workspace called "Example" and a Workset called "Metrostation". That is all I got when I installed mine
Thank you, Aubel. Florida DOT has a very solid ORD implementation, even though their level schema leaves much to be desired and there are many inconsistencies (mainly due to to too many cooks in the kitchen, as it were:-)). But still, many good things done there.
Mark
Thanks again Mark
You are so welcome, Aubel!
I am all sorted now with a new OpenRoads Designer, came with the general standards.
Excellent, Aubel. I am glad that the issue was finally sorted out.
Best Regards,
