Recently, I received another user's road Alg, used it, and modified it, and at some point, the file started running only with Read-Only, so I couldn't work. Read-Write works fine on other users' computers, but can only run on other computers. The same phenomenon continues even if you set it to Free on the user's computer for the first time, save it, receive and run the file. Does anyone have any experience in solving this problem?
I would suggest you to please go to C drive , Right click on C:\Program Files (x86) folder > Properties >uncheck "Read-Only" > Apply > Select "OK" to Apply changes to this folder, subfolders and files > Select "Continue" on the Access Denied dialog > Select "Ignore All".
After that you can launch software with "Run as Administrator" and then try to open .alg ?
Or you can go to the start menu and right click on the icon used to launch the product > Properties > Compatibility > toggle on "Run as Administrator" > restart the computer and launch software.
Purva Lakde
Ctrl + FREE
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/20337/alignments-are-locked
Hope it helps.
jing jing (o'.'o)
