Plotting Special Ditches in Sheets
I have been trying now for a while to try to figure out how to plot my special ditch in my profile sheet for my mainline alignment.  I cannot find any direction on how to do it.  Also, can I reference in a dgn file that has the special ditch profile in it or does the ditch profile have to be in the same file that my mainline profile/corridor is in?
Any help would be great!
  • There are a couple of methods, but one that seems pretty commonplace is to project the special ditch profiles onto your mainline alignment. A word of caution: if you use a feature definition for the special ditch profiles that has annotation definitions associated, it will place VPI and slope labels at much more regular intervals than you likely intend. This is because of how the software projects profiles from one element to anotehr. You can avoid this by not annotating those automatically, or using a feature definition that has no annotation associated with it.
    Another method is to actually store the ditch profiles on the mainline itself and then project them out to the ditches. This eliminates the issue with the improper annotation but can cause other downstream effects that you need to watch out for.
    Eddie Giese, PE
    Production Manager | Senior Roadway Engineer
    Licensed in FL & PA
    ACEC FDOTConnect Instructor on behalf of FDOT
    Patel, Greene & Associates, LLC
    PowerGEOPAK V8i SS10 (08.11.09.918)
    OpenRoads Designer 2021 R2 (10.10.21.4)
    OpenRoads Designer 2020 R3 (10.9.0.91)
    ProjectWise Explorer CE 10.0.3.453
    LumenRT CE Update 14 (16.14.60.98)
    premier-scholar-badge road-designer-badge
