Hi
When I load my itl file and apply feature def. to my template point. I have a list of pre-defined features i choose among, great. I would now like to change the layer, color etc. of the pre-defined features, for now impossible. I have been into the pre-defined dgn-lib that contains the feature definitions and symbologi, but.
1) I can not find the same features, available in the dgn-lib, as in the itl fil? So where does the itl file loads the feature definitions from
2) Where do I in general change layers, color etc. of a defined feature?
Anders,
To add to what Holly said:
1) The ITL Feature Definitions for Points are pointing to the "Linear" category of FDs. If you are looking for the Component Feature Definitions, they are looking in the "Mesh" category of the Standards Library.
2)The "Symbology" (level, color, line style, etc) are in Element Templates. The Feature Definition points to a Feature Symbology, which then points to an Element Template. The Element Template Manager can be found on the Home tab all the way to the left. It's hidden at the bottom of the Element Template Picker, just click the down arrow and at the bottom select "Manage"
