Open Roads Workspace & Workset setup for Work Server
I am having trouble setting up the workspace and worksets for our company. I moved the configuration folder to our "T" drive but I am having trouble setting up the worksets for each project considering the layout of our drive. We use different folders for each project and I am wondering if there is a way to make a workset for each of these while still using the same "standards" from the workspace. I have attached an image to possibly help with understanding the way our layout is. I have examples of our project folders and then the configuration folder on our "T" drive.
Also when a new workset is created is there any way to make it use the same standards that are already set up in our workspace folder or do they have to be copied for each workset.
  • The Organization-Civil folder an contain multiple Agency/Client/Whatever folders for as many different standards as you need. You can then define the variable CIVIL_ORGANIZATION_NAME to match the folder name and CFG filename stored in that folder, in the Workspace CFG file that the menu's call. These can be local folders or a network share.
    Additionally, once you move to ORD 2022 R1, the startup screen (or backstage after pressing Close (Ctrl+W) supports multiple configurations in multiple locations.
    We place most of our main workspace files in that main folder under Organization-Civil and while there is an entire folder structure under our WorkSpace for additional settings, we do not store many things in that structure.
    Workspaces are very different than prior releases, so even those of us that knew and understood CFG files "like the back of our hand" find ourselves having to relearn a lot. The changes with 2022 R1 are nice but did change how a number of things worked prior to it, so even that caused a few hours of head scratching and testing before I was comfortable with their new operation.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
  • I did both of these things and set up the configuration setup and the workspace setup on my local drive to direct it to the "T:\Configuration\Organization-Civil" folder but anytime I make a workset that doesn't also have all of those folders/files from the Standards in the "Organization-Civil" folder, none of our levels or anything are in the dgns that are created.
  • The capability mentioned in Paul Cusack's reply can be combined with the built-in workspace capabilities, to get Project Folders working in multiple locations. To accomplish the same thing in V8i took a lot of manual customization of many CFG files. At the other firms I worked, we generally had one person create the Project files on the network for everyone to use. While it might be possible to allow any user to create projects in the workspace, the steps necessary to accomplish this and to maintain uniformity and consistency might be too much to expect.
    CADD Manager
Reply
    CADD Manager
