Hi all,
When I attempt to add in the .shp file for either of the two seen in the image below, it gives me the error message at the very bottom of my ORD window that says "[...\Structures.shp] is not in a recognized file format.
Any help on why this may be the case?
Hi Buck,
please see the following article: GIS Files: Unable to Open, Import or Reference. This article says that there are required at least three files in the same directory, with the same name and different extensions. I was able to attach my .shp file, but in the same folder I have also some other file's extensions:
I hope this helps.
___
Also, please keep in mind that questions in English should be posted in the dedicated forum:
OpenRoads/OpenSite Forum (English).
This will help not only us, but also you to get a proper answer. I am moving your post to the English language forum. :)
Best regards,
Klaudia
