Hi all,
When I attempt to add in the .shp file for either of the two seen in the image below, it gives me the error message at the very bottom of my ORD window that says "[...\Structures.shp] is not in a recognized file format.
Any help on why this may be the case?
Hi Buck,
I recommend to follow the best practices and always specify used product including its version (e.g. using build number), preferably directly in subject (as defined for Programming forum best practices).
Buck Ralston said:When I attempt to add in the .shp file
Shapefile must always consists from at least 3 mandatory files (shp, shx, dbf) and optionally several more (see the format description on Wikipedia). Do you have all these 3 files? And where the shapefile comes from (how it was created)? Can it be opened in other software (like QGIS)?
Buck Ralston said:for either of the two seen in the image below
Sorry, but the shared picture is unreadable. Please share full resolution screen capture and attach to the discussion using Insert > Insert image/video/file tool.
With regards,
Jan
