I had a question about using the Expression Builder for Item types. I have my excel set up and the Item types but when I go to use the expression builder it gives me a choice for everything except the one I am currently trying to make an expression for. I added some pictures to show how my expression builder looks and the excel for reference. If anyone could help with how my expression should be set up that would be great!
Yes, make sure you have your ITEMTYPE_LOOKUP variable mapped to pull the excel sheet from your WorkSet location. You can have multiple instances of this variable, just make sure the appropriate operator is used in your CFGs.
2022R1 Item Type Test.dgn
5125.Project Information.xlsx
Justin Guiliano, PE
I believe I found the issue yesterday. I still had the extra information really far down on the excel. Thank you so much for all your help!
