Cross section annotation
Hello, my cross sections are not labeling the cross slopes of my proposed shoulders.  I am using the default cross section annotation  group.  Is there something I am doing wrong in my template design? How does the annotation group even know what to label? Is it based on points, lines, features? Thanks!
  • Matt,
    This looks like the FDOT workspace. If so, there is a limitation defined for slopes so that it doesn't label any segments that are 2.75-ft wide or less. I believe this is to reduce clutter. You can change this setting either at the workspace level or in your individual DGN files. In Explorer, go to Annotation Groups, right-click on XS Annotation and select Manage. Here is one example of where you can change that setting:
    Eddie Giese, PE
    Production Manager | Senior Roadway Engineer
    Licensed in FL & PA
    ACEC FDOTConnect Instructor on behalf of FDOT
    Patel, Greene & Associates, LLC
    PowerGEOPAK V8i SS10 (08.11.09.918)
    OpenRoads Designer 2021 R2 (10.10.21.4)
    OpenRoads Designer 2020 R3 (10.9.0.91)
    ProjectWise Explorer CE 10.0.3.453
    LumenRT CE Update 14 (16.14.60.98)
    premier-scholar-badge road-designer-badge
Reply
  • Matt,
    Eddie Giese, PE
    Licensed in FL & PA
