When viewing dynamic cross sections it always goes to an odd station, even when I say to start at 175+00, probably because the alignment starts at an odd station. The increment is correct. Is there a way to get this to work properly?
ORD 2021 R2
Lucas, what is your CVIL_DEFAULT_STATION_LOCK config variable set to? (in the Backstage under the Configuration Variables). It should be set to 1 to enable it. 0 means that it will ignore it. This has the same function as the InRoads Station Lock if you're familiar with that.
It is set to true.
Anyone else have thoughts on the problem. It's pretty annoying.
Hi Lucas, this is a logged bug/defect. When clicking through the different stations of dynamic sections, the stationing of each interval appears to be based off the alignment's beginning station and not the interval from the typed in specified station.
Bug 889263
Answer Verified By: Lucas Hicks
