Good Morning,
When I open files, I notice that the file opening dialog will read our dnglib files, the reference files for the dgn etc.
But then it will read dgn files that are not referenced in the .dgn, but that are within the same workset.
Sometimes it will get stuck on larger GDTM files that are not even referenced in the model, The only work around is to cut the extraneous files and remove it from the workset filepath.
I am unsure if this is a mapping issue with our configuration.
Are you working in ProjectWise?
Are you working in ProjectWise? We see this all the time when working in PW. We even see it loading files that are not even referenced to the active file. It is a major defect IMO.
We are not using ProjectWise.
Is it possible they are nested references? I know ProjectWise sometimes looks for references that are deeply nested and not needed. The core product might also do the same.
