I am currently using the FDOT State Kit and am running into issues with DTM's in ORD 10.10. I build the terrain models using the selection set method, from there I will deactivate survey processing rules, complete a preliminary trim of the triangles, extract a graphic of the DTM boundary, reactivate the survey processing rules and add the graphic boundary, from there I will continue to QC the DTM and make any necessary edits to the points and linework. I am noticing dozens of linear features being removed from the terrain model. They are set to breakline and have had to be included in the DTM at one point or another but as I make edits to the data I find more and more not in the DTM. On and 8 mile topo we are talking dozens. I have only started noticing this on my most recent projects so it coincides with the use of ORD 10.10. I can't imagine this being an issue with older versions since I have not noticed it in the past on other projects using previous versions of the software. Has anyone else ran into this issue? Anybody know the cause or have a better workflow that helps prevent it?
Adam
Mark,
Yes DTM = Terrain Model
ORD Version = 10.10.21.004
I am editing for instance linear features in the field book that make up the DTM, for instances I might changed the point geometry to edit curve/splines, etc.
Adding back the ones that were removed after my edits I currently select the linear feature, it is set to breakline although it is not in the current DTM, I change it to Do Not Include and then back to Breakline and it is added back into the DTM.
Maybe I'll have some time over the holiday to create a video showing the issue. I don't see how this isn't a glitch in the software. Does anyone at Bentley monitor this forum, is there someplace else I can submit the issue to them directly?
Thanks & have a good Thanksgiving.
Thanks for answering those questions Adam!
Yes, Bentley monitors this forum, but you should log it through your support contract. Posting it here isn't officially bringing it to their attention.
Are you (or FDOT) using Dynamic Link Linear Features or Point List Linear Features? ... or do these happened to be Graphical Linear Features?
And I was going to ask you to do a video, but held back ; )
Have a good T-day yourself too!
