Hi, say if a top soil component is child to the end condition which is being rounded. Is there a way to have the top soil component to follow the rounded end condition completely? tied several different ways but no luck, I guess the number of points for the rounding is hardcoded in with a fix number of points that is causing the top soil component to fail? Thanks,
Yes, the rounding points is hard coded to 4 points. I am not sure if this is requested in our new IDEAS portal, but it would be a great place to search and create an idea for Product Management/Development.
https://bentleyopencivil.ideas.aha.io/ideas
I have never played with creating an arc component for the end of a component, but you may can utilize an arc component. The arc component is created between 2 points defined in the template, so you would need to place a point where your 'rounding' would start and then create the arc component between that point and the point constrained to the target point of the end condition. It wouldn't act exactly like the rounding option, but would get you some points created along the component so the triangulated mesh and the component appear to have some arc to it.
Video: Arc Component
