Hi all,I'm currently using OpenRoads Designer constructing models of a designed tunnel. I have defined the tunnel linning structure like this is the template library.After template drops, the arcs displayed as rather line strings (broken lines rather than smooth curves).How can I possibly make the tunnel lining looks smooth?Big thanks in advance.Regards,Chris
Hi Chris.
ORD doesnt create extruded circle solids, but Meshes based on points and this is also how it does Circles. You can increase the "smoothness" by setting the number of points you want it to create via a variable noted in the links below.
Openroads Template Arc/Rounding/Fillet Stroking Values - OpenRoads | OpenSite Forum - OpenRoads | OpenSite - Bentley Communities
Circular Component - Stroke value for mesh creation - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities
Mark
Hi Mark,Thanks for the quick answer, I set the stroke number to 100 and now the arcs appear very much like arcs in 3D view.There is another problem here though, as I define the template as tunnel lining (void in the internal space inside tunnel intrados, when the display style is set to modelling, the internal spaces are all filled. Anyway to solve this? Maybe I should start a new thread concerning this as the original issue is well solved.Thanks again,Chris
