ORD Annotate distance between two null points on cross section
Hi
Using ORD 2022 R1, hoped it would be finally possible to annotate the distance between two points that don't create physical segments. For example I am in need to annotate distance from CL to the ROW, or from ROW to fence. Really do not want to create dummy components.
Moreover, in some site designs, I use surface templates, no corridors there. I would like to annotate crossfall between two points that don't belong to segment.
Is is possible now with ORD 2022R1 and cross-sections annotation?
Appraciate your help :)
