How I can create custom cross section bands
How I can create custom cross-section bands in open road designer like showing the yellow area in the attached image?
in the workspace where I can find the setting for it?
  • When using place named boundary for civil cross sections, the create drawing dialog allows selection of an annotation group that is configured within the workspace and can produce the rows of text in the cross section annotation.
    This is the location of the annotation group in the training and examples workspace
    After creating drawings in the active file the annotation group will be copied to the active file and can be further modified. Once the annotation group is part of the active file it will be used for any further annotation within the active file. To modify the annotation group within the active file, right click on it and select "manage" from the menu.
    The following dialog then displays that allows for modification of the annotation group settings
    Answer Verified By: Muhamamd Abrar
Reply
