Replace a horizontal alignment
I am trying to replace an existing horizontal alignment with a new horizontal alignment that is an offset of a third element. The original horizontal alignment already has vertical geometry and a corridor associated with it. I have already tried the append element and complex redefine tools to no avail, as well as the key-in geometry element replace. I was unable to use the keyin Geometry Substitute. I get an "unknown keyin" error. I am using MicroStation SS10 08.11.09.916.
Thank you
Parents Reply Children
  • Hi Marc,
    What the tool looks to do is transfer the Horizontal Geometry Feature Name, Feature Definition and Civil instance links from one element to another (so it is identified to all related objects as the same thing in the active model and all references), but also transfers the entire Profile space as is from one element to another. No relinking or anything like that required - hence why it is such as great tool to quickly completely redefine geometry and keep all dependent relationships alive.
    Mark
    OpenRoads Designer 2023  |  Microstation 2023.1  |  ProjectWise 2023
