hello guys,
i created earthwork wizard and after that when export it to autocad,error creating file panel shown and mx is closed without export the plan & plofile,
but when i export it to autocad without create earthwork wizard,it work.
so how to fix this problem when work with earthwork wizard.
i am using mX SS3.
Hello Anurag,
Did you get any error when you export Earthwork to AutoCAD? If yes, please share any snapshot of the error.
Please upload your dgn file in the given link below so that I can test it at my end and provide you possible solution at the earliest?
https://bentley.sharefile.com/r-ra1afbb53d7554e848c6f0d194a816aa2
Purva Lakde
hello mam
thanks for your response. yes i get error.i send you snapshot and also dgn file.
What are your setting in the options when exporting to dwg?
Especially at the References and Filter tab.
i razmik
i send you snap.
h
Hello mam can you please reply my quarry I sent to by open road forum
