I have imported drillhole data from an SHP file and would like to map feature definitions based on data field values for the imported elements.
In the picture below I have a line that includes a data field for Bergklass (Rock quality class) with a set value of "B" and I would like to set every element that has value "B" to a certain color.
Is this possible without using macros? And if not, can anyone guide me in how I could set up a macro?
Kind regards,
Lucas
Using Explorer, the Items tab includes a search field that can be used to select the elements with the specified item type properties. The set feature definition tool can then be used to assign the specified feature definition to the selected elements.
communities.bentley.com/.../the-explorer-part-three-the-items-tab
Answer Verified By: Lucas Olsson
This is perfect, thank you!
